[GRASS-dev] g.copy bug?
Glynn Clements
glynn at gclements.plus.com
Mon Apr 23 14:27:09 EDT 2007
Martin Wegmann wrote:
> Hello,
> g.copy from mapsetA -> mapsetB does not work witht the most current cvs
> version.
> if I run g.copy rast=old at mapsetX,test1725heute
> d.rast test1725heute
> WARNING: can't read range file for [test1725heute in habitat_amount]
> WARNING: color support for [test1725heute] in mapset [habitat_amount]
> missing
> ERROR: Color file for [test1725heute] not available
> r.support test1725heute
> WARNING: Can't open header file for [test1725heute in habitat_amount]
> Edit header for [test1725heute]? (y/n) [y]
> Edit header for [test1725heute at habitat_amount]
> WARNING: unable to open raster map [test1725heute in habitat_amount]
> ERROR: Cannot open raster map [test1725heute]!
> ERROR: Canceling from edit header.
> r.info test1725heute
> WARNING: category support for [test1725heute] in mapset [habitat_amount]
> missing
> WARNING: can't get history information for [test1725heute] in mapset
> [habitat_amount]
> ERROR: could not read range file
> unfortunately my grass6 / 62 Debian versions are broken hence I cannot test it
> using these releases.
> can anybody report this bug as well?
I can't reproduce this with a 2-day-version, which is after the recent
changes involving qualified names. I tried:
$ g.mapsets mapset=glynn
$ g.mapsets -p
glynn
$ g.copy elevation.dem at PERMANENT,foo
Copy raster <elevation.dem at PERMANENT> to current mapset as <foo>
$ ls /opt/grass-data/spearfish57/glynn/cell_misc/foo/
null range
There may be other factors involved; can you create a minimal location
which demonstrates the issue?
> BTW is there a way to move raster between mapsets?
Change to destination, g.copy, change to source, g.remove.
There isn't a faster way; you can't modify mapsets other than the
current one.
