[GRASS-dev] [grass-code I][455] r.proj segfaults after Jul 14
changes
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Aug 8 14:11:14 EDT 2007
On Wed, 8 Aug 2007, William Kyngesburye wrote:
> Actually, it's more than just G_done_msg - there are a few G_message(NULL) in
> there, and the r.proj source is really in r.proj.seg, the r.proj source
> folder is deprecated.
> Not to mention the other modules I found null messages in, as I mentioned in
> a followup to the bug report.
> If (NULL) is indeed improper use of the message functions, I could take care
Well apart from passing NULL instead of an empty string being obviously
wrong, a message that actually contains no information would appear to be
improper use by definition, no? What's the point of it?
Just seems like an obvious remark to make anyway...
Paul
