[GRASS-dev] GRASS 6.3.0 release preparation
Michael Barton
michael.barton at asu.edu
Wed Aug 22 15:30:21 EDT 2007
Thanks for the information Massimo.
Michael
On 8/22/07 12:03 PM, "massimo di stefano" <massimodisasha at yahoo.it> wrote:
> Hi,
> i do not know if this is usefool for the list,
> using grass6.3.cvs, i tried to "annotate"
> some really smooll issues that i had during my study :
> 1)
> using the grass-addons v.out.ascii.db i have this error log :
> Multiple tables: using first one [bugsites]
> sort: unrecognized option `--'
> Try `sort --help' for more information.
> v.out.ascii.db done.
> i modify in the script from :
> # sort both by cat
> sort -n --field-separator='|' --key=$N "$COOR_TMP" > "$COOR_TMP".s
> sort -n --field-separator='|' "$ATTR_TMP" > "$ATTR_TMP".s
> to :
> # sort both by cat
> sort -n -t '|' -k $N "$COOR_TMP" > "$COOR_TMP".s
> sort -n -t '|' "$ATTR_TMP" > "$ATTR_TMP".s
> now seems that works fine.
> 2)
> when i start grass i have this message :
> Rebuilding Addon HTML manual pages index...
> cat: global_i.atcorr.html: No such file or directory
> but the i.atcorr help page is regulary available
> 3)
> v.type.sh
> works if it is called from the gui or from the TCL-shall,
> but not works if it is called from the bash shall
> coping the scripts v.type.sh
> from "../etc/gui/scripts/"
> to "../Resources/Scripts/"
> solved the problem
> 4)
> from the gui menu :
> vector -> network analisys -> shortest route visualization only (d.path)
> i have :
> can't read "xmonlist": no such variable
> while executing
> "lindex $xmonlist 0"
> (procedure "guarantee_xmon" line 16)
> invoked from within
> "guarantee_xmon"
> invoked from within
> ".#menubar.#menubar#menu3.#menubar#menu3#menu12 invoke active"
> ("uplevel" body line 1)
> invoked from within
> "uplevel #0 [list $w invoke active]"
> (procedure "tk::MenuInvoke" line 50)
> invoked from within
> "tk::MenuInvoke .#menubar.#menubar#menu3.#menubar#menu3#menu12 1"
> (command bound to event)
> the same problem that affect "d.nviz" ?
> 5)
> starting the module v.build
> whent the gui of this module is started, i have a "crazy moving" of the window
> contents.
> resizing the window, moving the botton right corner of the tcl window fix the
> "crazy moving"
> need to change :(GRASS_WIDTH= , GRASS_HEIGHT= ) ?
> 6)
> in v.digit :
> after i add a new line to an existant vector file :
> i had this message :
> Cannot update table:
> DBMI-DBF driver error:
> SQL parser error: syntax error, unexpected WHERE, expecting NAME processing
> 'where'
> in statement:
> update str_11 set where cat = 2
> Error in db_execute_immediate()
> but checking in the vector, i see that the new object is added without issue.
> 7)
> using v.db.add.table i've :
> dbmi: Protocol error
> Error while executing: "CREATE TABLE str_11 at kml (cat integer)
> Cannot continue.
> it do not accept the "@" character
> Il giorno 11/ago/07, alle ore 23:05, Michael Barton <michael.barton at asu.edu>
> ha scritto:
>> I think that 6.3 stable is ready. With the exception of the the segfault
>> with r.proj (fixed or on its way to being fixed), I don't know of any
>> serious issues on-going with 6.3. Most of the recent changes I've seen come
>> across the dev list have been improvements or enhancements.
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070822/a5c4a829/attachment.html
