[GRASS-dev] GRASS 6.3.0 release preparation
Michael Barton
michael.barton at asu.edu
Thu Aug 23 01:04:38 EDT 2007
Massimo,
I checked into these 2 GUI issues.
#4) Works for me. It opens an xmon and a terminal with a prompt to pick a
vector network map. Your description of the menu entry suggests that you are
using an old version. I changed this menu entry several months ago when I
shortened all menus and changed menu nesting to more more than 2 subentries
deep. Now it should be vector->network analysis->display shortest route. Try
updating to a current version and see if it fixes it. If not, we need to
find out why the TclTk procedure guarantee_xmon is not producing a valid
list of xmons using d.mon -L. Try this command and see what happens.
#5) I have the same problem. It stems from the TclTk window being opened to
exactly the pixel height that bisects the last checkbox control. I don't
know why it is not opening a bit further by default. This is part of the
autogenerated TclTk dialogs for GRASS commands. I only very generally know
how this works. So I'm not sure how to fix it. I'll see if I can figure out
what is setting the window height.
Michael
On 8/22/07 12:03 PM, "massimo di stefano" <massimodisasha at yahoo.it> wrote:
> 4)
> from the gui menu :
> vector -> network analisys -> shortest route visualization only (d.path)
> i have :
> can't read "xmonlist": no such variable
> while executing
> "lindex $xmonlist 0"
> (procedure "guarantee_xmon" line 16)
> invoked from within
> "guarantee_xmon"
> invoked from within
> ".#menubar.#menubar#menu3.#menubar#menu3#menu12 invoke active"
> ("uplevel" body line 1)
> invoked from within
> "uplevel #0 [list $w invoke active]"
> (procedure "tk::MenuInvoke" line 50)
> invoked from within
> "tk::MenuInvoke .#menubar.#menubar#menu3.#menubar#menu3#menu12 1"
> (command bound to event)
> the same problem that affect "d.nviz" ?
> 5)
> starting the module v.build
> whent the gui of this module is started, i have a "crazy moving" of the window
> contents.
> resizing the window, moving the botton right corner of the tcl window fix the
> "crazy moving"
> need to change :(GRASS_WIDTH= , GRASS_HEIGHT= ) ?
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070822/542cf06a/attachment.html
