[GRASS-dev] compile directions
Gerald Nelson gnelson at uiuc.edu
Fri Aug 24 12:37:24 EDT 2007
Yeah, but no directions on when to do each. A conservative approach would be to do make distclean just to be sure. But would that ever cause problems?
Jerry
---- Original message ----
>Date: Fri, 24 Aug 2007 12:27:26 -0400
>From: "Patton, Eric" <epatton at nrcan.gc.ca>
>Subject: RE: [GRASS-dev] compile directions
>To: "William Kyngesburye" <kyngchaos at kyngchaos.com>, "Gerald Nelson" <gnelson at uiuc.edu>
>Cc: <grass-dev at grass.itc.it>
>There are instructions in the INSTALL file distributed with Grass on the difference between the two:
>make clean - delete all files created by 'make'
>make distclean - 'make clean' + delete all files created by './configure'
>~ Eric.
>-----Original Message-----
>From: grass-dev-bounces at grass.itc.it on behalf of William Kyngesburye
>Sent: Fri 8/24/2007 1:17 PM
>To: Gerald Nelson
>Cc: grass-dev at grass.itc.it
>Subject: Re: [GRASS-dev] compile directions
>Actually, I'm a little guilty, though I often ask others when
>troubleshooting.  I usually just run "make clean".  If I see a change
>in configure or a makefile, then I'll run "make distclean".
>Occassionally I'll make distclean anyways, to be safe.
>I don't know how valid my method is - assuming that only configure
>and makefile changes require a distclean.  But something in the build
>instructions would probably be good.
>On Aug 24, 2007, at 10:19 AM, Gerald Nelson wrote:
>> There have been lots of emails recently about compiling issues, and
>> one common thread is a question about whether you ran 'make
>> distclean' first.
>> Is there any reason NOT to always run make distclean? Should it be
>> part of the standard directions?
>William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>http://www.kyngchaos.com/
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
