[GRASS-dev] gpde library and groundwater flow modules
Sören Gebbert
soerengebbert at gmx.de
Fri Feb 16 05:07:14 EST 2007
Hi William,
thanks for this report, this is obviously a bug.
My build system seems to be much too tolerant.
I have hopefully fixed this issue in CVS,
because i can not reproduce this
on two Linux machines (dual P3 and Athlon 3000+ with Debian etch, gcc 4.1).
Best regards
Soeren
William Kyngesburye schrieb:
> Hm, no good. Rather than the missing gpde symbols Michael Barton had, I
> get missing G3D symbols.
> I see that grass.make has G3D now for gpde linking. But the gpde
> makefile doesn't link the library itself to G3D. And the lib makefile
> still builds gpde before G3D.
> On Feb 15, 2007, at 5:45 PM, Soeren Gebbert wrote:
>> Hi folks,
>> i just committed a huge update for the gpde library and the
>> groundwater flow
>> modules to CVS.
>> Please consider a "make distclean" and rebuild grass if you make a CVS
>> update,
>> because i needed to modify the file Grass.make.in.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> [Trillian] What are you supposed to do WITH a maniacally depressed robot?
> [Marvin] You think you have problems? What are you supposed to do if
> you ARE a maniacally depressed robot? No, don't try and answer, I'm
> 50,000 times more intelligent than you and even I don't know the answer...
> - HitchHiker's Guide to the Galaxy
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
