[GRASS-dev] [bug #5497] (grass) r.in.wms
Request Tracker grass-bugs at intevation.de
Fri Feb 16 10:23:37 EST 2007
this bug's URL: http://intevation.de/rt/webrt?serial_num=5497
Subject: r.in.wms
Power Mac G5
PowerMac7,2
PowerPC 970  (2.2)
# CPU:	2
CPU:	1.8 GHz
  Caché level 2 by CPU:	512 KB
  Memory:	1 GB
  bus:	900 MHz
  ROM:	5.1.4f0
Binary downloaded from www.kynchaos.com GRASS 6.3.0-CVS-07020401
r.in.wms fails with the following:
(Projecte):/Applications/Grass/GRASS_63_cvs_070205.app/Contents/Resources >
r.in.wms layers=global_mosaic mapserver=http://wms.jpl.nasa.gov/wms.cgi
output=wms_global_mosaic srs=EPSG:4230
wms.request
'folder=/Volumes/LaCieDisk/Users/Shared/agus_compartido/grassdata/wms_download'
'prefix=wms_global_mosaic' 'mapserver=http://wms.jpl.nasa.gov/wms.cgi'
'layers=global_mosaic' 'srs=EPSG:4230' 'format=geotiff'
'wmsquery=version=1.1.1' 'maxcols=1024' 'maxrows=1024'
Calculating tiles
usage: units [-f unitsfile] [-q] [-v] [from-unit to-unit]
/Applications/Grass/GRASS_63_cvs_070205.app/Contents/Resources/scripts/r.tileset:
line 1: [0]=SOURCE_PROJ: command not found
line 1: [1]=1: command not found
line 1: [2]=DEST_PROJ: command not found
line 1: [3]=SOURCE_TO_DEST: command not found
line 1: [0]=DEST_PROJ: command not found
line 1: [1]=SOURCE_PROJ: command not found
line 1: [2]=1: command not found
line 1: [3]=DEST_TO_SOURCE: command not found
(standard_in) 2: parse error
Rel. 4.4.8, 3 May 2004
<cs2cs>:
projection initialization failure
cause: no arguments in initialization list
program abnormally terminated
(standard_in) 1: illegal character: U
<cs2cs>:
<cs2cs>:
<cs2cs>:
(standard_in) 1: parse error
line 1: =${0[p_source_proj_p]}: bad substitution
line 1: =${1[p_source_units]}: bad substitution
line 1: =${2[p_dest_proj_p]}: bad substitution
line 1: =${3[p_dest_units]}: bad substitution
(standard_in) 1: illegal character: S
(standard_in) 1: illegal character: O
(standard_in) 1: illegal character: R
(standard_in) 1: illegal character: _
(standard_in) 1: illegal character: X
(standard_in) 1: illegal character: T
(standard_in) 1: illegal character: P
(standard_in) 1: illegal character: I
(standard_in) 1: illegal character: N
<cs2cs>:
line 1: =: command not found
<cs2cs>:
<cs2cs>:
<cs2cs>:
Requesting 0 tiles!
wms.download
'requestfile=/Volumes/LaCieDisk/Users/Shared/agus_compartido/grassdata/wms_download/wms_global_mosaic_.wget'
'wgetoptions=-c -t 5 --user-agent=MSIE5.5'
Downloading tiles
All tiles downloaded successfully
r.in.gdalwarp  -c 'output=wms_global_mosaic' 'method=nearest' 's_srs=EPSG:4230'
ERROR: Required parameter <input> not set:
    (Raster file or files to be imported. If multiple files are specified they
will be patched together.).
-------------------------------------------- Managed by Request Tracker
