[GRASS-dev] Re: [Qgis-developer] Windows native GRASS build
Tim Sutton
tim at linfiniti.com
Fri Jan 5 10:25:50 EST 2007
Hi Radim
I can make another build but probably not until monday. If the patches
go into grass cvs that will be great cause then I can just update &
build.
Regards
Tim
On 1/5/07, Radim Blazek <radim.blazek at gmail.com> wrote:
> Thanks Marco!
> -mwindows helped, attached is patch for Grass.make.in
> and dbf driver Makefile. Similar change must be done in
> Makefiles of all drivers. configure must be run because
> Grass.make.in is source for Grass.make
> It would be nice if this patch or something similar could be applied
> to GRASS CVS head and 6.2 release branch.
> Tim can you patch your GRASS in MSYS and create a new build?
> We dont have to wait for 0.8.1 IMO because it does not include
> changes in QGIS, it is just a new binary build.
> Radim
> On 1/3/07, Marco Hugentobler <marco.hugentobler at karto.baug.ethz.ch> wrote:
> > Hi Radim and Tim,
> > If the db driver is compiled with mingw gcc and you have the possibility to
> > recompile it yourself, you may use the linker option -mwindows. I don't know
> > of other possibilities to avoid the console (but I am no win expert too).
> > Marco
> > Am Montag, 1. Januar 2007 18:30 schrieb Tim Sutton:
> > > Hi
> > > > > 1) Every time a layer is added a black console box temporarily appears
> > > > > and then disappears.
> > > > It is known problem, db driver is exe and when it is started by spawnl()
> > > > it opens Windows console for a while. I am not Win expert and I dont know
> > > > how to avoid this. I have asked already in QGIS and GRASS devel lists.
> > > Ok - I think its not a big problem for now.
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
