[GRASS-dev] r.proj.seg -> r.proj
Markus Neteler
neteler at itc.it
Fri Jul 20 03:44:39 EDT 2007
Done.
Old r.proj is deprecated; r.proj.seg was renamed to r.proj (in the
Makefile).
Markus
Markus Neteler wrote:
> Hi,
> if there are no objections, I will retire r.proj and
> rename r.proj.seg -> r.proj in GRASS 6.3-CVS.
> The file bilinear.c still contains a "Press" reference,
> does it still hold true since it uses G_interp_bilinear()?
> Markus
View this message in context: http://www.nabble.com/r.proj.seg--%3E-r.proj-tf4113655.html#a11703602
Sent from the Grass - Dev mailing list archive at Nabble.com.
