[GRASS-dev] GRASS and GDAL 1.4.1 MingW
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Thu Jun 14 08:50:25 EDT 2007
Hamish wrote:
> Benjamin Ducke wrote:
>> 2. However, the README is not clear on whether GRASS first needs to be
>> compiled w/o GDAL support firdst, but I assume it has to, because it
>> won't be able to find GDALOpen and the configure script aborts:
>> 3. Fair enough, BUT: with the current CVS version, it seems impossible
>> to compile GRASS without GDAL support, as compilation in
>> lib/vector/Vlib aborts, even if I specify --without-gdal:
> GDAL is now a formal dependency. compiling without it is a bad idea.
> the order should be:
> 1. compile & install GDAL without grass support
> 2. compile & install GRASS linking to the new GDAL
> 3. compile & install GDAL's GRASS plugin linking to the new GRASS.
Step 1: OK
Step 2: Fails:
checking for gdal-config... /usr/local/bin/gdal-config
checking for GDALOpen... no
configure: error: *** couldn't find GDAL
Would this be the time to remove --without-gdal from the configure
script?
Best,
Benjamin
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
