[GRASS-dev] GRASS and GDAL 1.4.1 MingW
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Thu Jun 14 09:42:04 EDT 2007
I just tried installing the GDAL version contained in the
wingrass-extralibs package:
http://grass.gdf-hannover.de/wiki/WinGRASS_Current_Status
following the precise steps as outlined here:
With a fresh update of GRASS CVS
Still the same configure error:
checking for gdal-config... /usr/local/bin/gdal-config
checking for GDALOpen... no
configure: error: *** couldn't find GDAL
What am I doing wrong?
Benjamin
Benjamin Ducke wrote:
>>> 2. However, the README is not clear on whether GRASS first needs to be
>>> compiled w/o GDAL support firdst, but I assume it has to, because it
>>> won't be able to find GDALOpen and the configure script aborts:
>>> 3. Fair enough, BUT: with the current CVS version, it seems impossible
>>> to compile GRASS without GDAL support, as compilation in
>>> lib/vector/Vlib aborts, even if I specify --without-gdal:
>> GDAL is now a formal dependency. compiling without it is a bad idea.
>> the order should be:
>> 1. compile & install GDAL without grass support
>> 2. compile & install GRASS linking to the new GDAL
>> 3. compile & install GDAL's GRASS plugin linking to the new GRASS.
> Step 1: OK
> Step 2: Fails:
> Would this be the time to remove --without-gdal from the configure
> script?
> Best,
> Benjamin
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
