[GRASS-DEV] In wxgrass File menu import vector calls v.out.ogr
Agustin Diez Castillo Agustin.Diez at uv.es
Mon Jun 18 11:39:45 EDT 2007
wxgrass gui is calling the wrong command.
At least here, menu Files -- Import raster map -- mutiple format
using gdal is calling r.out.gdal instead of r.in.gdal
same with Files -- Import vector map -- mutiple format using ogr is
calling v.out.gdal instead of v.in.ogr
On Jun 15, 2007, at 8:10 PM, Michael Barton wrote:
> Because this is somewhat complicated to do, there are probably some
> hidden
> gotchas in there somewhere (command arguments with spaces will
> probably fail
> currently, for example; we're trying to fix this). But it should
> work for
> 90%+ of what people will do.
> Michael
>>> full command line access to all GRASS commands; d.* commands
>>> called from the
>>> command line can display in the wxPython canvas.
>> This is great. I was missing such functionality for gis.m's map
>> canvas.
>> Maciek
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070618/3889be70/attachment.html
