[GRASS-dev] make install fails with 6.3 CVS
Maciej Sieczka tutey at o2.pl
Wed Mar 14 13:59:30 EDT 2007
Glynn Clements wrote:
> Maciej Sieczka wrote:
>> Current 6.3 CVS builds fine, but on make install a bunch of:
>> tar: path/to/file: file changed as we read it
>> is issued (full log of make install is attached).
> I'm guessing that if you don't specify --prefix, the configure script
> isn't substituting the default prefix until after we've used it. I
> just need to quote ${prefix} so that it doesn't get substituted.
You fixed it. Thanks.
Maciek
