[GRASS-dev] Re: Not universal building on Mac
massimo di stefano massimodisasha at yahoo.it
Wed May 9 12:01:53 EDT 2007
i have the same problem (nviz crash)
to avoid any conflict with other libraries that i've installed on my
mac  (intel machine)
i formatted the HD
i installed osx on it
  Xcode and GCC
now i'm tring to buid grass on a fresh osx 10.4.9 installation
(so i'm sure that there is not external library or
somethink like fink-darwinports environment that can be a possible
conflict)
to install grass as first step,
i installed the tcltk library (8.14) from source as suggested in the
readme file.
then i tried to configure grass63-cvs =
cvs downoad ...
cd ../grass6
make distclean
./configure --prefix=/Applications --enable-macosx-app --enable-sysv
--with-x
--with-opengl=x11
--with-cxx
--with-freetype
--with-freetype-includes=/Library/Frameworks/FreeType.framework/unix/
include
--with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
--with-gdal=/Library/Frameworks/GDAL.framework/Versions/1.4/Programs/
gdal-config
--with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
--with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
--with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
--with-jpeg
--with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/
include
--with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-tiff
--with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/
include
--with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/
include
--with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-sqlite
--with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
--with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/
include
--with-fftw
--with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
--with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib
--with-postgres-includes=/usr/local/pgsql/include
--with-postgres-libs=/usr/local/pgsql/lib
--with-tcltk-includes=/usr/local/tcltk/include
--with-tcltk-libs=/usr/local/tcltk/lib
--x-includes=/usr/X11R6/include/
--x-libraries=/usr/X11R6/lib/
--with-python
--enable-largefile
export TCLTKPREFIX=/usr/local/tcltk/
make
sudo make install
.configure  give me not errors
idem with  make
butr try to use nviz ... it crash!
again i tried to configure grass with the same .configure,
but in usr/local instead of /application :
./configure --prefix=/usr/local/       .......(without : --enable-
macosx-app ) ...
i've the same results (nviz crash)
note:
using the --prefix=/usr/local
grass start with a native aqua gui and no x11
  (can this hep to indagate the nviz problem ?)
Massimo.
Il giorno 09/mag/07, alle ore 17:24, grass-dev-request at grass.itc.it
ha scritto:
> I did make distclean before compiling. On the binary nviz is still
> crashing
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070509/159f898d/attachment.html
