[GRASS-dev] Re: [GRASS-user] Nviz on native Windows
Paul Kelly
paul-grass at stjohnspoint.co.uk
Sat May 19 05:06:12 EDT 2007
On Fri, 18 May 2007, Michael Barton wrote:
> You can do *almost* anything from the GUI that you can do from the command
> line. Apparently, nviz is the biggest problem--but I don't know why it
> shouldn't run.
Nviz was working great on Windows until early December (even with
Michael's new improvments and tidying of the GUI) when Bob changed it
back to use a shell script-based startup instead of starting the binary
directly. Obviously that doesn't work on Windows and that meant it no
longer got regularly tested on Windows. Now, if I switch it back to
generate the binary directly (see attachment) it still doesn't work - gets
stuck on the Please Wait stage again - so I guess some other incompatible
thing was changed in the meantime. I suppose worth trying with different
Tcl/Tk versions though.
I don't like committing patches that seem like the best way to solve a
problem but are only part of the solution (i.e. its still broken after
the patch but the patch was my best effort sort of thing), as it may
hinder somebody else's efforts to fix things in the future, so have
attached to this e-mail.
Paul
Index: Makefile
RCS file: /home/grass/grassrepository/grass6/visualization/nviz/Makefile,v
retrieving revision 1.13
diff -u -r1.13 Makefile
--- Makefile 24 Jan 2007 15:42:34 -0000 1.13
+++ Makefile 19 May 2007 08:57:21 -0000
@@ -8,7 +8,7 @@
VER=2.2
NV_VER=nviz$(VER)
PROG=nviz
-NVWISH_VER=$(PROG)
+NVWISH_VER=NVWISH$(VER)
INSTALL_DIR=$(GISBASE)/etc/$(NV_VER)
SCRIPTDIR=$(NV_VER)/scripts
@@ -39,9 +39,6 @@
$(INSTALL) scripts/nviz_params $(INSTALL_DIR)/scripts/nviz_params
### ACS - END #################################################################
$(INSTALL) scripts/*Index $(INSTALL_DIR)/scripts
- $(INSTALL) -m 755 scripts/$(PROG) $(GISBASE)/bin
- if test -f "src/nvwish.exe" ; then mv src/nvwish.exe $(INSTALL_DIR)/$(NVWISH_VER) ; fi
- if test -f "src/nvwish" ; then mv src/nvwish $(INSTALL_DIR)/$(NVWISH_VER) ; fi
(cd bitmaps; tar -cf - * | (cd $(INSTALL_DIR)/bitmaps; tar -xf - 2>/dev/null ); true)
$(INSTALL) scripts/$(NV_VER)_script $(INSTALL_DIR)/scripts
(cd html ; $(MAKE) )
Index: src/Makefile
RCS file: /home/grass/grassrepository/grass6/visualization/nviz/src/Makefile,v
retrieving revision 1.22
diff -u -r1.22 Makefile
--- src/Makefile 10 May 2007 19:18:48 -0000 1.22
+++ src/Makefile 19 May 2007 08:57:21 -0000
@@ -53,16 +53,15 @@
ARCH_OBJS := $(foreach obj,$(OBJS),$(OBJDIR)/$(obj))
-#PGM = nviz
-#default: $(BIN)/$(PGM) htmlcmd
-default: nvwish
+PGM = nviz
+default: $(BIN)/$(PGM) htmlcmd
#gsf:
# cd $(SURF_INCDIR) ; $(GMAKE)
# touch nviz_init.c
-nvwish: $(ARCH_OBJS) $(VECTDEP) $(BITMAPDEP) $(LINKMDEP) $(FORMDEP) $(DBMIDEP $(GISDEP)
+$(BIN)/$(PGM): $(ARCH_OBJS) $(VECTDEP) $(BITMAPDEP) $(LINKMDEP) $(FORMDEP) $(DBMIDEP $(GISDEP)
$(CC) $(LDFLAGS) -o $@ $(ARCH_OBJS) $(FMODE_OBJ) $(SURFLIB) \
$(BITMAPLIB) $(LINKMLIB) $(VECTLIB) $(SITESLIB) $(FORMLIB) $(DBMILIB) \
$(G3DLIB) $(GISLIB) $(XDRLIB) \
Index: src/nvizMain.c
RCS file: /home/grass/grassrepository/grass6/visualization/nviz/src/nvizMain.c,v
retrieving revision 2.11
diff -u -r2.11 nvizMain.c
--- src/nvizMain.c 26 Apr 2007 20:42:38 -0000 2.11
+++ src/nvizMain.c 19 May 2007 08:57:21 -0000
@@ -52,13 +52,30 @@
int i;
+ int passed_count;
+ char **passed_args;
Tcl_FindExecutable(argv[0]);
- if (argc > 1) {
- if (strstr(argv[argc-1], "-h") != NULL)
- sprintf(argv[argc-1], "--h");
+ /* I suppose what this is doing is inserting "--" into the stream of
+ * command-line arguments to tell Tcl it's the end of the arguments
+ * meant for it and the start of those meant for nviz?? PK */
+ if (argc > 1 && strncmp(argv[1], "-f", 2) != 0 )
+ passed_count = argc + 1;
+ passed_args = (char **) G_malloc(passed_count * sizeof(char *));
+ for (i = argc; i > 1; i--)
+ passed_args[i] = G_store(argv[i-1]);
+ passed_args[1] = G_store("--");
+ passed_args[0] = G_store(argv[0]);
+ else
+ passed_count = argc;
+ passed_args = argv;
- Tk_Main(argc, argv, NVIZ_AppInit);
+ Tk_Main(passed_count, passed_args, NVIZ_AppInit);
return 0; /* Needed only to prevent compiler warning. */
