[GRASS-dev] Re: select issue with wingrass
Moritz Lennert mlennert at club.worldonline.be
Tue Nov 6 10:12:56 EST 2007
On 06/11/07 03:16, Michael Barton wrote:
> I have a postdoc who just arrived to learn a bit of GRASS in my lab
> today. He installed WinGRASS about a week ago. It launches fine. But he
> cannot see any of the map files inside the mapset when he tries to add a
> map to a GUI window. This is controlled by select.tcl. We checked this
> against the Spearfish dataset and confirmed that the data are fine and
> that he does have access to the maps. In fact, if he types in a map
> name, any module seems to run fine--including displaying a map in the
> GIS Manager.
> When you click a button to launch select.tcl, you get a window/dialog
> with a tree which shows available mapsets and, if they exist, any
> accessible maps in the mapset. You can select a map and click OK.
> Everything works for Javi except seeing the maps inside the mapsets. He
> can even see the mapsets (first level of the tree); just not the maps
> inside a mapset.
> A first guess on my part is something to do with translating forward
> slash for *nix and Mac "/" to backward slash for Windows "\". The odd
> thing is that this worked fine with earlier builds of WinGRASS, so maybe
> it's something else.
> Have either of you guys run into this?
No, I've never had that problem. I'll test, but won't be in front of a
win machine before tomorrow.
Moritz
