[GRASS-dev] select issue with wingrass
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Fri Nov 9 05:34:56 EST 2007
Michael Barton wrote:
> Glynn, Moritz, and Benjamin,
> Tried this and it worked fine. Downloaded and installed the current (2
> November) binary and still have the same problem.
To re-iterate Moritz's line of thought: were is the data stored? Are you
accessing it over the network? Could there be a permissions problem with
Javier's user account? Is he allowed to look into the folders for the
mapsets?
> Now were are constantly getting an error with dbf.ext when we are trying to
> create points from a DBF table (only 6 points). The table is fine (checked
> in OpenOffice).
Some troubles with the DBF driver on Win have been reported on the QGIS
mailing list as well, but this seems to be a separate issue. What
exactly is the error message?
> If there is a problem with Javier's installation, what do we need to do to
> completely clean it off and try again? (maybe keep TclTk since it seems to
> be OK?).
WinGRASS does no tinker with any system files. Simply delete the whole
installation folder and you are rid of it.
Benjamin
> Michael
>>> I agree that it certainly looks like the problem code is
>>> glob -nocomplain $path/*
>>> "glob" ought to work because it is pure TclTk in this case (although
>>> identical to the unix command). What about the "*"?
>>> I don't know how to test this on Windows. Suggestions?
>> Run tclsh in a console, and type e.g.:
>> glob -nocomplain C:/*
> __________________________________________
> Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
