[GRASS-dev] select issue with wingrass
Michael Barton
michael.barton at asu.edu
Fri Nov 9 13:27:51 EST 2007
On 11/9/07 10:59 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
> On 09/11/07 18:41, Javier Fernandez wrote:
>> Hi all, I have attached a word file with the problems that I find when I
>> work with wingrass,
> Thank you. Could you give the precise commands/actions you take to see
> these errors ?
> e.g.:
>> Problem 2: Unable to create points from a dbf. File: because a dbf error
>> Output GIS
>> NG: GRASS_TRUECOLOR status: TRUE
>> PNG: collecting to file: C:\grassdata/Spain_utm_30n/PERMANENT/.tmp/928.0.ppm,
>> GRASS_WIDTH=575, GRASS_HEIGHT=484
>> Unable to open vector map <Yaci at PERMANENT> on topology level 0
> and then you show a screenshot of the windows error message. But what do
> you do to get this result ? The above error message ("Unable to
> open...") seems to be related to displaying a map, whereas you say it is
> linked to v.to.db ?
The screenshot is an error caused by v.in.db.
Michael
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
