[GRASS-dev] select issue with wingrass
Moritz Lennert mlennert at club.worldonline.be
Fri Nov 9 13:43:33 EST 2007
On 09/11/07 19:27, Michael Barton wrote:
> On 11/9/07 10:59 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
>> On 09/11/07 18:41, Javier Fernandez wrote:
>>> Hi all, I have attached a word file with the problems that I find when I
>>> work with wingrass,
>> Thank you. Could you give the precise commands/actions you take to see
>> these errors ?
>> e.g.:
>>> Problem 2: Unable to create points from a dbf. File: because a dbf error
>>> Output GIS
>>> NG: GRASS_TRUECOLOR status: TRUE
>>> PNG: collecting to file: C:\grassdata/Spain_utm_30n/PERMANENT/.tmp/928.0.ppm,
>>>      GRASS_WIDTH=575, GRASS_HEIGHT=484
>>> Unable to open vector map <Yaci at PERMANENT> on topology level 0
>> and then you show a screenshot of the windows error message. But what do
>> you do to get this result ? The above error message ("Unable to
>> open...") seems to be related to displaying a map, whereas you say it is
>> linked to v.to.db ?
> The screenshot is an error caused by v.in.db.
Could you send the content of the 'technical information' (link in the
error window) of the error reports ? I'm not sure I'll understand these
(MS does not have the reputation of creating useful error messages...),
but it's worth a try.
Moritz
