[GRASS-dev] GRASS cvs for Mac compilation fails for OS X 10.4
Michael Barton michael.barton at asu.edu
Sat Nov 17 10:41:29 EST 2007
On 11/17/07 8:29 AM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> The install fails?  Or it fails to run?
> The install doesn't care anything about what version of X11 you have.
> Running is already conditionalized for the X11 version.  What errors
> are you getting?
The compilation and install goes fine. It won't run wish. I did NOT install
a different TclTk, but am using the one I compiled from source several
months back, following directions in your README.
Here is the error.
/Applications/Grass/GRASS-6.3.app/Contents/MacOS/scripts/gis.m: line 17:
/Applications/Grass/GRASS-6.3.app/Contents/MacOS/bin/wish: No such file or
directory
exec: /Applications/Grass/GRASS-6.3.app/Contents/MacOS/bin/wish: cannot
execute: No such file or directory
When I try to run wish, this is what I get
wish
dyld: Library not loaded: /usr/local/X11R7/lib/libX11.6.dylib
  Referenced from: /usr/local/lib/libtk8.4.dylib
  Reason: image not found
Trace/BPT trap
Michael
> On Nov 17, 2007, at 12:55 AM, Michael Barton wrote:
>> William,
>> I just tried to install GRASS from the cvs. It fails on my OS X 10.4
>> machine because it is hard coded to look for x11r7 (with OS X 10.5)
>> instead of x11r6. Can this be conditionalized to deal with 10.4 AND
>> 10.5?
>> Michael
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian]  What are you supposed to do WITH a maniacally depressed
> robot?
> [Marvin]  You think you have problems?  What are you supposed to do if
> you ARE a maniacally depressed robot?  No, don't try and answer, I'm
> 50,000 times more intelligent than you and even I don't know the
> answer...
> - HitchHiker's Guide to the Galaxy
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
