[GRASS-dev] things to do before the 6.3.0 release
Thu Nov 22 13:26:27 EST 2007
Hamish wrote:
> 2) d.vect default render mode in 6.3 has been changed to "l" from "g".
> For me (using xmons) this creates poorly rendered polylines and lots
> of bad artifacts in the "whitespace padding" at the edges.
> see examples here:
>   http://bambi.otago.ac.nz/hamish/grass/bugs/d.vect/
>  (IIRC the min line width!=0 problem shown at the bottom of that page has been corrected)
> Due to this I propose the default rendering should go back to "g" in the 6.3.0 release branch.
What's wrong with r, d and c?
g should only be used if none of the others can be made to work.
To get rid of the problem with render=l drawing beyond the edge of the
region, d.vect needs to set the raster clip window (R_set_window()) to
match the region (D_setup() sets it to match the frame), but it needs
to be set back afterwards (D_setup(0) should suffice).
Also:
1. d.vect uses the same rendering mode for both fills and strokes,
which isn't necessarily desirable.
2. There should probably be two polyline clipping functions. One which
fills the gap where a section has been clipped out, and one which
doesn't.
