[GRASS-dev] Cairo monitor driver
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Mon Oct 15 17:56:53 EDT 2007
Can you give some examples of the usage? (not the final product, but
the commands)
thanks
Carlos
On 10/15/07, Lars Ahlzen <lars at ahlzen.com> wrote:
> Brad Douglas wrote:
> >>> I can of course post code too, if anyone would be interested in actually
> >>> trying it.
> >> The code would certainly be useful.
> > +1
> The source is up! Sorry about the delay.
> I do realize that this is not the ideal format. A patch against the
> current 6.3 CVS tree would probably have been better, but apparently CVS
> doesn't let you add files even to your local copy without write access
> to the repository... oh well..
> Anyhow, the code along with brief build and usage instructions are
> available at:
> http://lars.ahlzen.com/cairograss/
> The makefiles are a bit of a hack and need to be fixed. Hopefully
> they'll work, though. And the code in general is, as previously
> mentioned, experimental. But it can always be cleaned up if it seems
> worthwhile.
> Feel free to try it out, and let me know if (when?) you run into
> problems building or using it, or if you have any other feedback!
> I don't know what the policy is for posting experimental code like this
> to the patch tracker, so given its current state I opted for not doing
> this. Let me know if I should.
> / Lars
> Lars Ahlzen
> lars at ahlzen.com
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
              Carlos Henrique Grohmann - Guano
  Visiting Researcher at Kingston University London - UK
  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
Linux User #89721  - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
