[GRASS-dev] Wingrass and TclTk
    Moritz Lennert
    mlennert at club.worldonline.be
    Fri Oct 26 12:16:28 EDT 2007
On 26/10/07 17:38, Benjamin Ducke wrote:
> Hmm, I get exactly the same crash when running with ActiveTcl (see
> screenshot)
> I did:
> nviz elev=height
> nviz
> (nviz started via gis.m)
I do not use msys for running grass under windows.
I can launch nviz from the cmd.exe with 'nviz -q' or 'nviz
elev=elevation.dem'. I can launch it from the Gis Manager via the File
menu, via the nviz button in the Map Display and by typing nviz -q (or
others) in the "shell" at the bottom of the Output window.
Just tried via msys and everything works perfectly as well.
  > Maybe it's because I am running this in a VMWare virtual machine
> and/or on a Windows 2000 system.
> I'll try on some real Win hardware and XP later.
> Another thing: is the --with-opengl=windows option working on MSYS?
What do you mean by "working" ? I use it and I get 'OpenGL support: yes'
at the end of configure.
> I'll do some more tests tomorrow. Too tired for today.
Maybe you could try with my binaries to see if that makes any difference.
Moritz
