[GRASS-dev] v.in.dwg: status in GRASS 6.2.2, DWGdirect, etc.
Glynn Clements
glynn at gclements.plus.com
Sat Sep 15 16:20:29 EDT 2007
Markus Neteler wrote:
> Yes: these files you have to obtain from the OpenDesign Alliance.
> AFAIK we could distribute binaries of v.in.dwg if there were dynamic
> DWGDirect libraries available, but they aren't (at least not some months
> ago). Since they only provide static libraries (.a instead of .so), they get
> compiled into GRASS and hence fall under the "no distribution" restriction.
It doesn't make any difference whether the libraries are static or
dynamic.
Unless you can supply the OpenDWG/DWGDirect source code under a
GPL-compatible licence, you cannot distribute a binary which is linked
(statically or dynamically) against both the GRASS libraries and the
DWG libraries.
