[GRASS-dev] configure fails
Markus Neteler
neteler at itc.it
Sun Sep 23 16:09:16 EDT 2007
Moritz Lennert-2 wrote:
> Trying to compile under mingw, I get the following error during configure:
> "checking whether the Fortran 77 compiler (gfortran
> -Wl,--export-dynamic,--enable-runtime-pseudo-reloc) works... no
> configure: error: installation or configuration problem: Fortran 77
> compiler cannot create executables"
> I see that this is related to Brad's and Markus' changes of today. Does
> this mean that the fortran compiler in mingw is not sufficient ? Or is
> this an error in the configure file ? Also, do I absolutely need a fortran
> complier ?
> For what ?
> Reverting to the previous versions of configure.in and configure it runs
> without a problem.
> Moritz
Can you post the config.log somewhere? Otherwise we (Brad)
cannot figure out the problem.
It should certainly also work without Fortran compiler (did
you activate it?).
The changes are needed for the upcoming GPDE and gmath
consolidation.
Markus
View this message in context: http://www.nabble.com/configure-fails-tf4505468.html#a12850014
Sent from the Grass - Dev mailing list archive at Nabble.com.
