[GRASS-dev] ganim troubles in latest cvs
Kirk Wythers kwythers at umn.edu
Fri Sep 28 12:21:54 EDT 2007
Anyone having trouble with gnanim? I just did a cvs update and
rebuild today, and and getting the following error through the gui
(OS X):
ERROR: <res=0.0> ** invalid input **
     while executing
"exec g.region res=$pnmres"
     (procedure "GmAnim::switch_res" line 38)
     invoked from within
"GmAnim::switch_res 1"
     (procedure "GmAnim::load_files" line 47)
     invoked from within
     (procedure "GmAnim::do_run" line 29)
     invoked from within
"GmAnim::do_run"
     (procedure "GmAnim::parse_viewmaps" line 79)
     invoked from within
"GmAnim::parse_viewmaps $viewlist"
     (procedure "GmAnim::create_viewlist" line 33)
     invoked from within
"GmAnim::create_viewlist 1"
     ("uplevel" body line 1)
     invoked from within
"uplevel \#0 $cmd"
     (procedure "Button::_release" line 18)
     invoked from within
"Button::_release .animmaps_win.buttons.a"
     (command bound to event)
Kirk
