[GRASS-dev] 6.3.0 is out! please prepare binaries...
Markus Neteler
neteler at osgeo.org
Tue Apr 22 03:41:29 EDT 2008
To avoid a mess, we'll do 6.3.0.1 after
- backport of Makefile fix (done)
- backport of missing scripts as needed for Windows native (todo)
Thanks to Martin for the 6.3.0.1 idea.
Markus
On Mon, Apr 21, 2008 at 6:29 PM, Markus Neteler <neteler at osgeo.org> wrote:
> hi,
> On Mon, Apr 21, 2008 at 6:20 PM, Martin Landa <landa.martin at gmail.com> wrote:
> > 2008/4/21, Glynn Clements <glynn at gclements.plus.com>:
> > > Note: most of the imagery modules are missing in 6.3.0.
> > > The reason is that changes to the way that SUBDIRS was handled in
> > > imagery/Makefile resulted in most of the modules not being built. The
> > > specific change in question is r30999.
> > > Essentially, only the modules listed in $(FFTWBASED) and $(XMONBASED)
> > > are actually built (assuming that FFTW and X11 respectively are
> > > enabled). The modules which are supposed to be built unconditionally
> > > are actually never built.
> > > I have just committed a fix to the trunk (r31065), but all of the
> > > 6.3.0 binary packages which people have built will be missing the
> > > following modules:
> > > i.ask
> > > i.atcorr
> > > i.cluster
> > > i.find
> > > i.gensig
> > > i.gensigset
> > > i.group
> > > i.his.rgb
> > > i.maxlik
> > > i.rectify
> > > i.rgb.his
> > > i.smap
> > > i.target
> > > i.pca
> > > i.cca
> > very bad news after tagging 6.3.0, better to discover now then later,
> > thanks Glynn! I have backported fixed Makefile to releasebranch_6_3. I
> > am afraid we need to tag 6.3.0 again(?)
> *Can* we redo 6.3.0? Or go directly for 6.3.1?
> Markus
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
