[GRASS-dev] Re: v.category: opt=del was changed
Maciej Sieczka
msieczka at sieczka.org
Sat Dec 6 12:15:45 EST 2008
Martin Landa pisze:
> 2008/12/6 Maciej Sieczka <msieczka at sieczka.org>:
>> Such a change in user interface is not acceptable for GRASS 6. By
> well, you are right (reverted r34750).
Cool.
>> default all categories should be selected. I don't see a reason to
>> change the default behaviour in GRASS 7 either.
> new behaviour can be useful if you want to remove not all categories,
> but only selected one (well, you can always use v.edit for that).
So, given that v.edit already provides the functionality of removing
selected categories only (tool=catdel cats=), I suggest to revert to old
v.category opt=del behavior in GRASS 7 as well. There is no big enough
reason to change the interface in this regard IMO. I don't insist though.
Cheers,
Maciek
Maciej Sieczka
www.sieczka.org
