[GRASS-dev] Re: G_percent() usage; freeze;
backport "Fix bug in G_is_c_null_value()"?
Martin Landa
landa.martin at gmail.com
Sun Dec 7 05:23:43 EST 2008
2008/12/7 Hamish <hamish_b at yahoo.com>:
> re r34762, etc.
> G_percent() should stay at the start of the for loop. If the loop takes
> a long time to run, 0% should print before the first iteration has begun,
> and final 99/100% message in loop should not be printed before the last
> iteration is complete. Otherwise it seems to stall at 99% done, etc.
sorry, I got impression that G_percent should stay in the end of the
loop. G_percent() doxygen string updated (r34774).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
