[GRASS-dev] [GRASS GIS] #399: Added "backlink" functionality to r.walk, r.cost & r.drain
GRASS GIS trac at osgeo.org
Sat Dec 13 15:32:25 EST 2008
 Reporter:  cnielsen  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  major     |   Milestone:  6.4.0
Component:  Raster    |     Version:  unspecified
 Keywords:            |    Platform:  All
      Cpu:  All       |
 I have updated the r.walk, r.cost and r.drain modules to include
 "back-link raster" functionality. Currently the path created by
 r.drain does not necessarily take THE path through a cost surface,
 that the cost accumulation algorithm took to generate that cost
 surface. My updates add an "outdir" raster as an output from the
 r.drain and r.cost modules which creates a backlink raster, or a
 raster surface of the movements made to create the cost surface
 (recorded in degrees). I then modified r.drain to read this surface
 when it's given the "-d" flag.
 I have tested it on my win32/vista build (mingw/msys), but not on linux or
 mac builds. Since this is my first patch, I have added extensive
 commenting which can probably be removed later.
Ticket URL: <http://trac.osgeo.org/grass/ticket/399>
