[GRASS-dev] nviz broken for Mac OS X 10.5.6 and TclTk 8.5 aqua
William Kyngesburye woklist at kyngchaos.com
Sat Dec 20 16:14:32 EST 2008
On Dec 20, 2008, at 1:49 PM, William Kyngesburye wrote:
> Yeah, that worries me just a bit.  I'm putting the symlink note in
> my own distribution readme, along with a note of the option of
> setting GRASS_WISH and GRASS_TCLSH.
> I need to update the bindist readme to include that note.
> I could bring back a default setting in the startup (removed when I
> dropped TclTk X11 bundling).  Since the build system doesn't provide
> a tcltk version variable, I could test for the presence of wish8.5...
OK, I added some detection of wish8.5 and 8.4 so the symlinks are not
needed.  It starts with 8.5, then falls back to 8.4.  (It gives a
warning if Aqua 8.4 is found, and doesn't set GRASS_WISH then.)  It
should also work in the default OSX 10.4- shell setup where /usr/local/
bin is not in the PATH.
The user can still override GRASS_WISH and GRASS_TCLSH in their
bash_profile.
It's in dev6 branch now.  Delete those "wish" and "tclsh" symlinks and
give this a try.  If OK I'll backport it to release 6.4.
> On Dec 20, 2008, at 1:33 PM, Michael Barton wrote:
>> OK. That works. Thanks.
>> There are still issues for distributing this. Installing
>> ActiveStates TclTk is easy enough. However, the symlinks need to be
>> made or GRASS_WISH needs to be set to wish8.5 in order for GRASS to
>> recognize this TclTk and NOT use the system 8.4.
>> Michael
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of
the allied nations devoted an entire year exclusively to hating the
____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
