[GRASS-dev] nviz broken for Mac OS X 10.5.6 and TclTk 8.5 aqua
Michael Barton
michael.barton at asu.edu
Sun Dec 21 13:57:46 EST 2008
William,
I removed the symlinks, recompiled and nviz works fine. The GRASS
TclTk GUI still starts up in x11 mode unless I set GRASS_WISH in
my .profile. I have both aqua and x11 TclTk installed, so I guess I
need to find someone without the x11 mode and see what happens. It's
good that you fixed this because I found that the symlinks trashed my
TclTk for R; I had to reinstall it. Thanks for the quick fix.
Cheers
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On Dec 20, 2008, at 2:14 PM, William Kyngesburye wrote:
> On Dec 20, 2008, at 1:49 PM, William Kyngesburye wrote:
>> Yeah, that worries me just a bit. I'm putting the symlink note in
>> my own distribution readme, along with a note of the option of
>> setting GRASS_WISH and GRASS_TCLSH.
>> I need to update the bindist readme to include that note.
>> I could bring back a default setting in the startup (removed when I
>> dropped TclTk X11 bundling). Since the build system doesn't
>> provide a tcltk version variable, I could test for the presence of
>> wish8.5...
> OK, I added some detection of wish8.5 and 8.4 so the symlinks are
> not needed. It starts with 8.5, then falls back to 8.4. (It gives
> a warning if Aqua 8.4 is found, and doesn't set GRASS_WISH then.)
> It should also work in the default OSX 10.4- shell setup where /usr/
> local/bin is not in the PATH.
> The user can still override GRASS_WISH and GRASS_TCLSH in their
> bash_profile.
> It's in dev6 branch now. Delete those "wish" and "tclsh" symlinks
> and give this a try. If OK I'll backport it to release 6.4.
>> On Dec 20, 2008, at 1:33 PM, Michael Barton wrote:
>>> OK. That works. Thanks.
>>> There are still issues for distributing this. Installing
>>> ActiveStates TclTk is easy enough. However, the symlinks need to
>>> be made or GRASS_WISH needs to be set to wish8.5 in order for
>>> GRASS to recognize this TclTk and NOT use the system 8.4.
>>> Michael
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no
> particular pleasure I shall kill every ___ I can until the war is
> over. That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people
> of the allied nations devoted an entire year exclusively to hating
> the ____ it wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
