[GRASS-dev] Plan to build Package to use GRASS from R
Rainer M Krug
r.m.krug at gmail.com
Wed Jul 2 10:25:56 EDT 2008
On Wed, Jul 2, 2008 at 4:22 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2008/7/2 Rainer M Krug <r.m.krug at gmail.com>:
>> I finally started working on the implementation of grass commands from
>> R and most of the translation from the the output from
>> --interface-description is working. I just have one question at the
>> moment: some flags require "--" and others "-" and I could not fiind
>> any indication in the
>> --interface-description output which one uses which.
> I guess, basically one-letter flags use '-' othewise '--', e.g.
> <flag name="g">
> <label>
> Shell script style, currently only for report
> </label>
> <description>
> Format: layer type count min max
> </description>
> </flag>
> <flag name="overwrite">
> <description>
> Allow output files to overwrite existing files
> </description>
> </flag>
> -> '-g' / '--overwrite' (or '--o')
I thought the same, but look at r.buffer --help:
Flags:
-z Ignore zero (0) data cells instead of NULL cells
-q Run quietly
--o Allow output files to overwrite existing files
--v Verbose module output
--q Quiet module output
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Plant Conservation Unit
Department of Botany
University of Cape Town
Rondebosch 7701
South Africa
