[GRASS-dev] GRASS 7 development started
Maris Nartiss maris.gis at gmail.com
Wed Jul 30 02:23:29 EDT 2008
Hello all!
I understand that it's summer outside (for most of us) and thus nobody wants to sit inside and do any coding (including myself). Still I want to understand how GRASS 7 development will be done. This thread/discussion seems to end nowwhere.
Can somebody make small announcement what ordinary coders[1] should do?
Currently I see that most of development is done in trunk and Martin is merging back to develbranch_6 [2].
How long we are planning to sit on two chairs and when trunk (finally) will be broken?
IMHO "software engineers" should break trunk in incompatible way and ordinary "coders" should work on modules in devbranch_6 till trunk is fixed (after major incompatible lib changes). Then we could port modules from dev to trunk. IMHO there's no use to play catch-up-with-lib-changes for modules in trunk while libs are not GRASS-7 ready.
Sorry for rant,
Maris.
1. http://lists.osgeo.org/pipermail/grass-dev/2008-July/038992.html
2. http://trac.osgeo.org/grass/search?changeset=on&q=merged+from+trunk&page=4&noquickjump=1
2008/6/13, Markus Neteler <neteler at osgeo.org>:
> On Tue, Jun 10, 2008 at 7:04 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> Procedure:
>> Server-side:
>> - announce date/time of "indent" code reformatting
>> - publish the final parameter set
>> - run on 7.x.trunk, submit
>> - run on 6.4.branch, submit
>> You local SVN copy:
>> - DON'T UPDATE YET but run
>>    svn status
>> - files with local uncommitted changes ("M") need to be treated
>>   with the indent command on the *unsubmitted* changed files
>>   to avoid later update conflicts
>> - *then* update from SVN to re-sync with "svn update"
>> Makes sense? Can we go ahead?
> Getting curious now :)
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
