[GRASS-dev] Current state of wxPython GUI
Martin Landa landa.martin at gmail.com
Thu Mar 27 12:36:41 EDT 2008
2008/3/27, benjamin.ducke at ufg.uni-kiel.de <benjamin.ducke at ufg.uni-kiel.de>:
> Browsing to a GRASS DB location and selecting a mapset now works.
>  However, if I just enter the directorz manually, I get:
>  Traceback (most recent call last):
>   File "/usr/local/grass-6.3.svn/etc/wxpython/gis_set.py", line 676, in
>  OnStart
>     "set=LOCATION_NAME=%s" %
>  self.listOfLocations[self.lblocations.GetSelection()]])
>  IndexError: list index out of range
should be also fixed in trunk now
  http://trac.osgeo.org/grass/changeset/30764
>  1. File -> Georectify -> (select mapset and map) -> select group (leave
>  empty) -> "Create/edit group ..."
>  -> comes up with a dialog for i.group that does not let me input anything
>  (it looks fine, but all fields and buttons are non-responsive). Can only
>  close it after closing the main georectify dialog (note: i.group from
>  the command line comes up with the GUI and works jsut fine).
>  Error message on console is:
>   File "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/ge
>  orect.py", line 480, in OnPageChanged
>  tmplist = os.listdir(os.path.join(self.grassdatabase,self.xy
>  location,self.xymapset,'group'))
>  OSError
>  [Errno 2] No such file or directory: '/home/benni/grass-
>  db/borkeld/user/group'
This is for Michael...
>  2. The GRASS init shell script now dumps this message twice to the console:
>  "To run a command as administrator (user "root"), use "sudo <command>".
>  See "man sudo_root" for details."
>  I guess it attempts to run something with su privileges?
OK, I assume this is well-known 'sudo' behaviour issue on Ubuntu...
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
