[GRASS-dev] Re: [GRASS GIS] #104: saving display to tiff or ppm
garbled when NVIZ is not top window
William Kyngesburye
woklist at kyngchaos.com
Sun Mar 30 14:18:27 EDT 2008
On Mar 29, 2008, at 3:52 AM, Glynn Clements wrote:
> Post all of the output (xdpyinfo, glxinfo, nviz).
(I figured I should also drag the NVIZ window partially offscreen for
the test)
OSX 10.5.2, Core 2 Duo, Intel integrated GMA950 graphics
OpenGL 1.2, so I could only test pixmap
X11R7
GRASS SVN trunk
name of display: /tmp/launch-jYmVH4/:0
version number: 11.0
vendor string: The X.Org Foundation
vendor release number: 10300000
X.Org version: 1.3.0
maximum request size: 16777212 bytes
motion buffer size: 0
bitmap unit, bit order, padding: 32, LSBFirst, 32
image byte order: LSBFirst
number of supported pixmap formats: 7
depth 1, bits_per_pixel 1, scanline_pad 32
depth 4, bits_per_pixel 8, scanline_pad 32
depth 8, bits_per_pixel 8, scanline_pad 32
depth 15, bits_per_pixel 16, scanline_pad 32
depth 16, bits_per_pixel 16, scanline_pad 32
depth 24, bits_per_pixel 32, scanline_pad 32
depth 32, bits_per_pixel 32, scanline_pad 32
keycode range: minimum 8, maximum 255
focus: PointerRoot
number of extensions: 29
Apple-DRI
Apple-WM
BIG-REQUESTS
DAMAGE
DEC-XTRAP
DOUBLE-BUFFER
DPMS
Extended-Visual-Information
GLX
MIT-SCREEN-SAVER
MIT-SHM
MIT-SUNDRY-NONSTANDARD
RECORD
RENDER
SECURITY
SGI-GLX
SHAPE
SYNC
TOG-CUP
X-Resource
XAccessControlExtension
XC-APPGROUP
XC-MISC
XFIXES
XINERAMA
XInputExtension
XKEYBOARD
XTEST
XVideo
default screen number: 0
number of screens: 1
screen #0:
print screen: no
dimensions: 1280x778 pixels (433x263 millimeters)
resolution: 75x75 dots per inch
depths (7): 24, 1, 4, 8, 15, 16, 32
root window id: 0x3f
depth of root window: 24 planes
number of colormaps: minimum 1, maximum 1
default colormap: 0x21
default number of colormap cells: 256
preallocated pixels: black 0, white 16777215
options: backing-store NO, save-unders NO
largest cursor: 32x32
current input event mask: 0x0
number of visuals: 4
default visual id: 0x23
visual:
visual id: 0x23
class: TrueColor
depth: 24 planes
available colormap entries: 256 per subfield
red, green, blue masks: 0xff0000, 0xff00, 0xff
significant bits in color specification: 8 bits
visual:
visual id: 0x24
class: TrueColor
depth: 24 planes
visual:
visual id: 0x25
class: TrueColor
depth: 24 planes
visual:
visual id: 0x26
class: TrueColor
depth: 24 planes
GRASS 6.3.svn (spearfish60):~ > glxinfo
display: /tmp/launch-jYmVH4/:0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: SGI
client glx version string: 1.2
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_swap_control, GLX_MESA_swap_frame_usage, GLX_OML_swap_method,
GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_visual_select_group
GLX extensions:
GLX_ARB_get_proc_address, GLX_EXT_import_context, GLX_EXT_visual_info,
OpenGL vendor string: Intel Inc.
OpenGL renderer string: Intel GMA 950 OpenGL Engine
OpenGL version string: 1.2 APPLE-1.5.18
OpenGL extensions:
GL_ARB_transpose_matrix, GL_ARB_vertex_program, GL_ARB_vertex_blend,
GL_ARB_window_pos, GL_ARB_shader_objects, GL_ARB_vertex_shader,
GL_EXT_multi_draw_arrays, GL_EXT_clip_volume_hint, GL_EXT_rescale_normal,
GL_EXT_draw_range_elements, GL_EXT_fog_coord,
GL_EXT_gpu_program_parameters, GL_APPLE_client_storage,
GL_APPLE_specular_vector, GL_APPLE_transform_hint, GL_APPLE_packed_pixels,
GL_APPLE_fence, GL_APPLE_vertex_array_object,
GL_APPLE_vertex_program_evaluators, GL_APPLE_element_array,
GL_APPLE_flush_render, GL_APPLE_aux_depth_stencil,
GL_NV_texgen_reflection, GL_NV_light_max_exponent, GL_IBM_rasterpos_clip,
GL_SGIS_generate_mipmap, GL_ARB_shading_language_100,
GL_ARB_texture_border_clamp, GL_ARB_multitexture, GL_ARB_texture_env_add,
GL_ARB_texture_cube_map, GL_ARB_texture_env_dot3,
GL_ARB_texture_env_combine, GL_ARB_texture_compression,
GL_ARB_texture_mirrored_repeat, GL_ARB_shadow, GL_ARB_depth_texture,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_point_sprite,
GL_ARB_texture_non_power_of_two, GL_ARB_vertex_buffer_object,
GL_ARB_pixel_buffer_object, GL_EXT_framebuffer_object,
GL_EXT_texture_rectangle, GL_ARB_texture_rectangle,
GL_EXT_texture_env_add, GL_EXT_blend_color, GL_EXT_blend_minmax,
GL_EXT_blend_subtract, GL_EXT_texture_lod_bias, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_stencil_wrap, GL_EXT_texture_filter_anisotropic,
GL_EXT_separate_specular_color, GL_EXT_secondary_color,
GL_EXT_blend_func_separate, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_compression_dxt1,
GL_EXT_blend_equation_separate, GL_EXT_packed_depth_stencil,
GL_EXT_geometry_shader4, GL_APPLE_flush_buffer_range, GL_APPLE_ycbcr_422,
GL_APPLE_texture_range, GL_APPLE_pixel_buffer, GL_APPLE_object_purgeable,
GL_NV_blend_square, GL_ATI_texture_env_combine3,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 0 0 None
0x24 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 0 0 None
0x25 24 tc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 0 0 None
0x26 24 tc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 0 0 None
Save PPM:
Create PixMap Using GLX 1.1
Final Assembled Image will be 2048 x 2048
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
Writing Tile 4 of 9
Writing Tile 5 of 9
Writing Tile 6 of 9
Writing Tile 7 of 9
Writing Tile 8 of 9
Writing Tile 9 of 9
Assembling Tiles
Destroy Context
Destroy GLXPixmap
Destroy Pixmap
glXSwapBuffers: no context for this drawable
PPM image is OK.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of
the allied nations devoted an entire year exclusively to hating the
____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
