[GRASS-dev] build problems on Mac OS X 10.5.2.
William Kyngesburye
woklist at kyngchaos.com
Fri May 9 10:16:57 EDT 2008
On May 9, 2008, at 3:02 AM, crundel wrote:
> William pointed out the issue is with the -g flag being passed which
> for
> some unknown reason seems to result in the test programs compiling
> as OSX
> applications, hence that directory organization you were seeing, and
> then
I never really thought about it. It may be because of the way GCC
handles compilation vs linking. In configure, for a run test, it
compiles *and* links the test program in one step ($ac_link). When
the debug flag is used, GCC may be assuming that we want an OSX
application and quietly packages one up for us.
-g works in GRASS compilation later because all programs are compiled
to object files first (even if there is only one), then linked into
the program binary.
So, maybe it is kindof a broken configure - this app packaging problem
started in Xcode 3.0 on Leopard, and GRASS' configure doesn't know
about it yet.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of
the allied nations devoted an entire year exclusively to hating the
____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
