[GRASS-dev] build problems on Mac OS X 10.5.2.
John Kern
kernj at kernj.cnc.net
Fri May 9 10:38:07 EDT 2008
Hello,
Thanks for the help.
Just wanted to share in interesting nit. If you ditch the -g, ....
[Macintosh:grass/grass63_release/try] jkern% gcc -o try.dSYM -02 try.c
[Macintosh:grass/grass63_release/try] jkern% ls -l
total 40
-rw-r--r-- 1 jkern staff 171 May 2 16:04 try.c
-rwxr-xr-x 1 jkern staff 12612 May 9 06:59 try.dSYM
[Macintosh:grass/grass63_release/try] jkern% ./try.dSYM
the try.dSYM becomes the name of the executable which allows the
configure check to work.
-John
On May 9, 2008, at 1:02 AM, crundel wrote:
> I don't claim to understand the inner workings of gcc, particularly
> on the
> mac but I ran into the exact same issue you're having a week or so
> back. As
> William pointed out the issue is with the -g flag being passed which
> for
> some unknown reason seems to result in the test programs compiling
> as OSX
> applications, hence that directory organization you were seeing, and
> then
> failng to run as the configure script cannot locate the executable.
> If you
> just run the configure script with out any CFLAGS you should be able
> to get
> things at least compiling, 'env CFLAGS="" ./configure' is what
> worked for
> me.
> View this message in context: http://www.nabble.com/build-problems-on-Mac-OS-X-10.5.2.-tp17140529p17143187.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
