[GRASS-dev] georeferencer - inspiration from gvSIG ?
Moritz Lennert
mlennert at club.worldonline.be
Fri May 23 10:47:56 EDT 2008
On 23/05/08 15:47, Markus Neteler wrote:
> Hi Moritz,
> could you post some (links to) screenshots?
http://geog-pc40.ulb.ac.be/grass/misc/georef_gvSIG.pdf
This is an extract of the gvSIG user manual with the chapter on the
georeferencer. It contains screenshots + explanations.
Moritz
> Markus
> On Fri, May 23, 2008 at 2:06 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
>> Hello,
>> I've been working with gvSIG's georeferencing module lately, and I have to
>> say that it rocks ! It allows you to see where you put your GCP's not only
>> on the image to reference, but also on your base map and you can zoom into
>> the points and move them around as needed in both maps. This allows for very
>> precise georeferencing. You can also place and resize your image as you want
>> in the same canvas as the reference map. Etc...
>> It would be great to have something like this in GRASS if it is in any way
>> feasible. So, maybe an inspiration for someone who has the time and feels
>> inspired. Or for next years Google Summer of Code ?
>> Moritz
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
