[GRASS-dev] GRASS 7 development started
Glynn Clements
glynn at gclements.plus.com
Fri May 30 16:30:07 EDT 2008
Hamish wrote:
> > Any final comments before the entire source tree is
> > reformatted?
> Any thoughts on keeping the inter-branch svn merge effort low?
Don't merge?
Eventually, 7.x and 6.x are going to diverge by more than just
formatting.
> Q: With -br, is -bli1 needed so that things look like:
> if (a == b) {
> and not
> if (a == b){
No; that's controlled by -saf/-sai/-saw (there should be one for
"switch", but there isn't; it always adds the space).
> ? (prefer the former)
> for open braces functions, structs the { should not be indented 1 space from the newline though..
> maybe start with committing the change to one file and then put that
> up for public review.. (as two mega-commits would be a pain)
Anyone who wanted to comment on the formatting should probably have
done so in the month since this thread was started.
