[GRASS-dev] compilation success
William Kyngesburye woklist at kyngchaos.com
Thu Oct 9 09:44:21 EDT 2008
On Oct 9, 2008, at 4:38 AM, Glynn Clements wrote:
> Michael Barton wrote:
>> With William's recent fix, I got farther tonight on getting a working
>> wxPython nviz than ever before.
>> I still have to remove render.c, but otherwise compilation goes well.
>> When I select nviz from the map display, I now get a message box
>> saying "Please wait, loading data..." and I get a partial nviz
>> toolbar
>> (color picker and exit door). Then it sits. In the layer manager
>> output window, I get the following error.
>>   File "/Applications/Grass/GRASS-6.4.app/Contents/MacOS/etc
>> /wxpython/gui_modules/nviz_tools.py", line 1308, in
>> CreateControl
>> size=sizeW)
>> C++ assertion "!(style & wxSL_VERTICAL) || !(style &
>> wxSL_HORIZONTAL)" failed at ../src/mac/carbon/slider.cpp(98)
>> in Create(): incompatible slider direction and orientation
> The style parameter is set thus:
>        if sliderHor:
>            style = wx.SL_HORIZONTAL | wx.SL_AUTOTICKS | \
>                wx.SL_BOTTOM
>            sizeW = (size, -1)
>        else:
>            style = wx.SL_VERTICAL | wx.SL_AUTOTICKS | \
>                wx.SL_BOTTOM | wx.SL_INVERSE
>            sizeW = (-1, size)
> Although it doesn't explicitly say so in the documentation, I believe
> that SL_BOTTOM is only valid in conjunction with SL_HORIZONTAL.
> AFAICT, for SL_VERTICAL, you have to choose either SL_LEFT or
> SL_RIGHT.
> Glynn Clements <glynn at gclements.plus.com>
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
