[GRASS-dev] Compiling GRASS on Ubuntu
dasuni kannangara dasuni7 at gmail.com
Wed Apr 8 05:29:08 EDT 2009
Thanks Markus.  i followed the  instructions, still am getting the same result. I have attached a screen shot of the console. Please refer it and please reply what i can do to compile the codes properly. console
dasuni kannangara wrote:
> i am using ubuntu 8.10. I have downloaded grass 6.2.3 source code. I referred the INSTAL file and installed all pre requisites. I am trying to compile the source code now. But when i enter the command 'make', it says,
> Makefile:22: include/Make/Platform.make: No such file or directory
> Makefile:23: include/Make/Grass.make: No such file or directory
> make: *** No rule to make target `include/Make/Grass.make'.  Stop.
Have you configured the source code first with ./configure? See also (B)
COMPILATION in the INSTALL file.
> Please provide me step by step details on how to compile the source code.
1. get source code for grass-6.4.0RC3, this version is much better than
grass-6.2.3
2. run ./configure within the directory grass-6.4.0RC3 with your choice
of configuration options, optionally first ./configure --help to see
3. only now can you 'make' grass
see also grass wiki on compile and install [1]
[1] http://grass.osgeo.org/wiki/Compile_and_Install#Ubuntu
grass-dev mailing list
grass-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-dev
View this message in context: http://n2.nabble.com/Compiling-GRASS-on-Ubuntu-tp2603661p2604149.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090408/6c7c9379/attachment.html
