[GRASS-dev] Re: a better console and better diff
Michael Barton michael.barton at asu.edu
Sat Dec 19 01:16:19 EST 2009
I just committed an advanced command console in develbranch_6 r40053. The changes were too many to do a diff. Please give it a spin.
There are separate input and output widgets. The input widget has all the features described below. It also wraps the command so you can see it all without resizing the window or scrolling. As before, typing commands that return text will produce nice output in the output widget; typing d.* command that display something (i.e., non-interactive ones) will produce something in the display canvas.
There is now a console tab/page with the command input and output widgets, and a layer manager tab/page with display layers you can manipulate with a GUI. Upside: a cleaner, more compact, interface with all command-related controls grouped together (and somewhat easier to code). Previously, entering a command would switch to the output tab/page anyway if it was not already selected. Downside: if you display maps using d.* commands and then want to manage the display layers (drag-and-drop layer organization, change properties), you have to click the tab for the layer manager.
The only thing I'm still having trouble with is sizing the StyledTextCtrl widgets for input and output. I think the input widget should be a little shorter but neither STC's are responding to sizing methods. This should be solvable, but at least you can try out new command entry console in the meantime.
Michael
On Dec 11, 2009, at 3:16 PM, Michael Barton wrote:
> For those that ask, here is a set of screenshots showing using the
> proposed terminal to enter a simple grass command. Hard to capture the
> actual action, but perhaps this series 1-4 conveys it.
> http://www.public.asu.edu/~cmbarton/files/grass_screenshots/console1.jpg
> http://www.public.asu.edu/~cmbarton/files/grass_screenshots/console2.jpg
> http://www.public.asu.edu/~cmbarton/files/grass_screenshots/console3.jpg
> http://www.public.asu.edu/~cmbarton/files/grass_screenshots/console4.jpg
> Michael
> On Dec 10, 2009, at 6:54 PM, Michael Barton wrote:
>> A quick note. I forgot to mention that there is also command history
>> as before. Press ctrl-up or ctrl-down.
>> Michael
>> ____________________
>> C. Michael Barton
>> Director, Center for Social Dynamics & Complexity
>> Professor of Anthropology, School of Human Evolution & Social Change
>> Arizona State University
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> On Dec 10, 2009, at 5:51 PM, Michael Barton wrote:
>>> First, thanks to all who advised me on making a diff that actually
>>> patches correctly (I hope).
>>> Here is a console with full autocomplete and calltips. For GRASS 6.5
>>> I've put it on auto to show how it can work, but the autocompletion
>>> could move to control key combinations too.
>>> --Type a grass command. When you get to the ".", it brings up an
>>> autocomplete list of relevant commands. Keep typing (or mouse up/
>>> down)
>>> until you find the one you want and hit return.
>>> --Press <tab> to see full calltips of command syntax for each command
>>> entered (one command per line please)
>>> --As you type the command arguments, hitting "=" and "," following an
>>> "=[string]" combination will bring up context-sensitive lists of
>>> relevant maps or other data sets (e.g. regions where appropriate).
>>> --You can type ctrl-space to bring up a context sensitive list of
>>> maps
>>> for raster, vector, etc. at any place in the command.
>>> --Pressing return on the command line will run it.
>>> This will accept shell commands (redirects and pipes don't work but
>>> could), grass commands without arguments (brings up the GUI dialogs),
>>> and grass commands with the short form arguments (r.info mymap) as
>>> well as full grass commands with argument=value format.
>>> ****IMPORTANT WARNING***** Turn OFF the preferences/configuration for
>>> default raster color tables. This is causing a bug to affect any
>>> command entered from this console or the existing command prompt.
>>> console_example4
>>> .patch><ATT00001.txt><goutput.py><wxgui.py><ATT00002.txt>
