[GRASS-dev] Re: Raster lib in GRASS7
Glynn Clements
glynn at gclements.plus.com
Tue Jun 23 22:19:10 EDT 2009
Martin Landa wrote:
> I have moved selected fns from gislib to the new rasterlib. The list
> is very initial (some fns should be renamed, removed, etc.), I fixed
> also the modules to be compiled. The GIS and Raster library need to be
> clean up. The current stage is very initial.
> I am not sure if G__ structure from G.h should be completely
> initialized by GIS or Raster library or the structures from G.h should
> be split and initialized separately by both libraries?
As you've noticed, the latter was done.
However, the global change of G_set_window() to Rast_set_window() in
r38009 is wrong.
Rast_set_window() updates the raster window and the column mapping for
open rasters. It doesn't affect G__.window, which is used by
G_window_{rows,cols}() etc.
Some of the code which used G_set_window() will need to continue using
G_set_window(), some of it will need to use Rast_set_window(), and
some of it will need to call both.
Right now, I suspect that many (or even most) modules which used
G_set_window() are broken.
