[GRASS-dev] Re: Raster lib in GRASS7
Martin Landa
landa.martin at gmail.com
Wed Jun 24 16:49:01 EDT 2009
2009/6/24 Glynn Clements <glynn at gclements.plus.com>:
>> I have moved selected fns from gislib to the new rasterlib. The list
>> is very initial (some fns should be renamed, removed, etc.), I fixed
>> also the modules to be compiled. The GIS and Raster library need to be
>> clean up. The current stage is very initial.
>> I am not sure if G__ structure from G.h should be completely
>> initialized by GIS or Raster library or the structures from G.h should
>> be split and initialized separately by both libraries?
> As you've noticed, the latter was done.
thanks for cleaning it up.
I have prepared list of fns, see [1]. I would suggest to rename some
of them. Waiting for you comments.
Martin
[1] http://trac.osgeo.org/grass/wiki/Grass7/RasterLib
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
