[GRASS-dev] Re: [GRASS GIS] #598: MacOS X / OpenGL and Wxpython incompatible
GRASS GIS trac at osgeo.org
Mon May 11 17:14:31 EDT 2009
  Reporter:  vince   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  6.4.0
 Component:  NVIZ    |     Version:  svn-trunk
Resolution:          |    Keywords:
  Platform:  MacOSX  |         Cpu:  OSX/Intel
Comment (by kyngchaos):
 Are you building 64bit?  I had no problem in trunk for 32bit OSX.  How did
 you configure GRASS?  The key options are
 --without-glw --with-opengl=aqua --with-python --with-
 wxwidgets=/path/to/wxpython
 You can build --with-x at the same time, it's just used for the XDRIVER
 and shouldn't interfere with the OpenGL detection.
 If you configure with tcltk (for the original nviz), you must use an Aqua
 framework TclTk, since it shares the same OpenGL setting.
Ticket URL: <http://trac.osgeo.org/grass/ticket/598#comment:1>
