[GRASS-dev] backgrounding wxGUI, defaults for 6.x
Tue Sep 22 09:33:08 EDT 2009
Hamish wrote:
> Is it possible to have g.gui detach the GUI from the terminal prompt?
> That is typically what you'd want to happen. ^Z + bg are redundant
> keystrokes / cumulatively lost moments. The man pages shouldn't have
> to suggest to do "g.gui $GUI &".  g.gui isn't the program, it's just
> the launcher.
Change g.gui to use G_spawn_ex() with SF_BACKGROUND.
