[GRASS-dev] recent updates to Vlib break vectors in GRASS 7
Michael Barton
Michael.Barton at asu.edu
Wed Dec 29 00:29:23 EST 2010
So what changed to make it show up now?
The main question is how to fix it.
My configure string always has included a set of paths to proj. I'm using the same configure string now that I was using a few days back when GRASS 7 compiled without errors.
./configure --with-freetype --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj --with-geos=/Library/Frameworks/GEOS.framework/Programs/geos-config --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-cairo --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include" --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib --with-cairo-ldflags="-lcairo" --without-postgres --without-mysql --with-odbc --with-sqlite --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x --with-cxx --with-opengl=aqua --without-readline --prefix=/Applications/GRASS --enable-macosx-app --with-python --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.11.0/bin/wx-config --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers /Library/Frameworks/Tk.framework/Headers /Library/Frameworks/Tk.framework/PrivateHeaders" --with-tcltk-libs="/usr/local/tcltk_active/lib" --with-macosx-archs="i386 x86_64"
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 28, 2010, at 9:33 PM, Glynn Clements wrote:
> William Kyngesburye wrote:
>> It's VECT_INC and is set in one of the makefile fragments, I think. It
>> used to be all in grass.make. Glynn's the master of all that makefile
>> magic.
> VECT_INC has been empty for a long time now, and it never contained
> $(PROJINC) directly or indirectly.
> It was first added to Grass.make.in in r11189 on 2003-02-27, at which
> time it had the value $(PQINCPATH). It stayed that way until r12781 on
> 2004-05-21, when it became empty. And it has been empty ever since.
> Any code which uses PROJ headers should be using $(PROJINC).
> You may be thinking of VECT_CFLAGS, which is defined as:
> VECT_CFLAGS = $(GDALCFLAGS) $(GEOSCFLAGS)
> FWIW, I suspect that this issue may have been hidden in the past due
> to "gdal-config --cflags" providing the necessary switches. GDAL
> itself uses PROJ, although its headers don't require the PROJ headers.
> Glynn Clements <glynn at gclements.plus.com>
