[GRASS-dev] scripts don't launch GUI from the msys command line in
winGRASS
Glynn Clements
glynn at gclements.plus.com
Thu Feb 4 14:58:54 EST 2010
Michael Barton wrote:
> #### first issue
> So far, I've only seen this in Vista and am wondering if anyone else has
> seen it. Using the nightly build from 2 February.
> From the command line, type the name of a script, like r.blend,
> without arguments
> Instead of the GUI popping up, there is an error complaining about the
> lack of arguments.
What error, exactly?
> ### second issue
> Also, copy a script and rename the copy (e.g., copy r.blend to
> r.blend2), leaving it in the scripts folder, then copy the script's
> *.bat file (in bin), rename the copy (e.g., , e.g., r.blend.bat to
> r.bend2.bat), and edit the *.bat file so that it points to the proper
> renamed script copy (e.g., now points to r.blend2). Type the script's
> name on the msys command line and press return.
> There is an error that the script cannot be found.
