[GRASS-dev] Re: [GRASS GIS] #908: No Font Definition File, windows xp
GRASS GIS trac at osgeo.org
Fri Feb 5 14:11:04 EST 2010
  Reporter:  voncasec      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  critical      |   Milestone:  6.4.0
 Component:  Installation  |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  v.label.sa, g.mkfontcap, wingrass
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:2 hamish]:
 > maybe for GRASS 7 we should first check for it in ~/.grass7/fontcap, and
 if not found there look for it in $(ETC)/fontcap?
 The code which reads the file uses $GRASS_FONT_CAP if it is set and the
 file can be read, otherwise $GISBASE/etc/fontcap.
 If g.mkfontcap is run without the -s flag, the data will be written to
 $GRASS_FONT_CAP if it is set, otherwise to $GISBASE/etc/fontcap. If
 $GRASS_FONT_CAP is set but the file cannot be written, it fails.
Ticket URL: <https://trac.osgeo.org/grass/ticket/908#comment:3>
